Lowering your CYA will most likely increase your FC usage per day at this time of year. If my pool drops to 60 ppm, it starts using 5+ppm FC per day. At 70 to 80 ppm CYA, I use about 4 ppm FC per day.
No experience with RO. I know you do have to have 0 algae, you will still need to add about 25% make up water, and it will cost in the $1000 range.
All pool equipment prices have gone way up. See
Compare and Review Saltwater Chlorine Generator Prices and Features for SWCG's. You would need one rated for 60K. So the RJ60 from Circupool would be a good fit.
