Im currently replacing a steel wall pool. I was going to use another pool kit because I thought it would be easier, but that's not the case, so im going with rebar and shotcrete.
I have dug a 2' x 2' trench around the old steel walls and im hoping to pass through some 2" PVC through the walls to get to the trench on the other side of the slab surrounding the pool.....Shouldn't be a problem.
My question is: Is there anything I need to know about creating a whirlpool for my skimmers? Where should my returns be and where should my skimmers be? How deep below the water line do the returns need to be?
My current opening is 15 x 35. The deep end is roughly 8' deep.
thank you
thank you
