- Apr 29, 2018
- 328
- Plaster
- CircuPool RJ-60
Pool built in 2000. All I have on the three returns are outside threaded pipes with a small narrowing of the inside of the pipe for an eyeball.
The outside cap of this picture, which I bought, fits on the existing threads coming out of my plaster walls. (Without eyeball) However the rotating eyeball piece inside is too large to fit in the pipe. I used my dremmel and sanded the eyeball down to make it work however this really wasn’t a great fix. Are there. Different sized eyeballs available (not diameter of the eyeball opening but a smaller eyeball ). I have reached into the return and it appears there is no way to remove the threaded piece and change it. I can feel the end of the short piece but have no idea how they installed them. I think the must be glued.
I do not feel any slot in the inside of the pipe but I do feel the end of it. Is this a pressed fitting? Glued? Threaded?
Any my advice on how or where to find the correct eyeballs?
