Happy pool opening season! Sort of…
Once again, we are plagued by a startup issue. We just started our pool an hour or so ago, but one return isn’t working. We have taken out the plugs (obviously) and gone from waste to filter a couple times hoping it would magically repair itself, but no dice.
It was working at the end of the season just fine. It was plugged all winter and we did put antifreeze in it. Also, we live in Virginia so it never gets that cold here to hard freeze anyway.
I’m attaching pictures of the pump and pool. The pump is a considerable distance from the pool and uphill (not our decision). We have three returns that I circled. The one in red is the one that doesn’t work. We aren’t sure where the main pipe from the pump to the pool splits into the two sides of the pool because we have no access to the plans when they put it in. The only other info that may be important is that I took apart the pump last year to deep clean the sand. We didn’t turn it back on after that.
I honestly have no clue what to do because nothing is coming out. A couple small bubbles when it first started, but nothing after. The problem return has been one in the past that has lost pressure when we were using the filter balls and they got gunked up. Once I got those out and put sand back in, the pressure returned to normal. It was also one that had the pipe behind it replaced because it pulled away from the pool wall and started leaking.
Any ideas of troubleshooting before I call a professional? I am also checking the water level to see if there’s any loss indicating an underground break. HELP!
