My old 1960 plaster pool's skimmer doesn't do much with my new variable speed Intelliflo pump, so I had the good idea of adding on a PoolSkim to the deep end return line and replacing the eyeball fitting. The issue is the return line is 1.5" copper and the eyeball is the original 1960 Landon faceplate that sits into an unthreaded large copper opening (see images below). The outer diameter of the faceplate of the eyeball is about 3 7/8", the inner tube diameter is about 2 3/8". Meaning that something like a stub pipe adapter wouldn't work, as the largest version I can find is designed to slide into 1.5" pipe and that is too small.
My only thought thus far is have a metal shop fabricate a new faceplate out of stainless with a 1.5" female thread that would match the old eyeball's opening and 3 mounting screws. Obviously I am trying to avoid re-piping or altering the existing returns at this point.
Any ideas or products that could work? Thanks!
