Hey guys, I'm working on a reno on my 1964 gunite pool. It was originally built as a heated pool and the builder plumbed twenty (20) returns around the pool. Fourteen (14) returns are around the perimeter of the pool and six (6) returns are in the floor of the pool. I have pressure tested my lines and everything is working; however, the return fittings are all worn out and broken with no way to divert the flow or close off the flow so I want to replace them all. All of the twenty (20) returns were plumbed with 1/2" (yes, half inch) black poly pipe. Without having to repipe the whole pool I was wondering if anyone has had any luck with retrofitting any type of return fitting to the 1/2" black poly? I bought a Pentair 1" Insider Eyeball Fitting 542000 which is designed to slip fit inside a 1" pipe and it actually slip fits outside the 1/2" poly but I don't want to run into a situation in a few years where I might have to bust up around the fittings to replace them if I have to. I'd rather find someway to retro fit a 1 1/2" eyeball return to the 1/2" poly. Has anyone had any luck doing this?
