tommelton
I've updated his picture with labels for each pipe so far - just waiting for the last 2.
K,
The goal here is to know for sure what is what, so double check you know which of the three valves does what.
Turn your deck jets one and off. Which valve is it?
Turn your bubblers on and off. Which valve is it?
Turn the pool returns on an off. Which valve is it?
Almost done, just have to talk about the spa spillover.
I think Tom may be keeping track as I am busy following ordersTime to start labeling these valves ---------
Ok, the 2nd valve from the right is the return on/off. If off the bubblers get all the water.Ok.. Hit me with any questions.
Tom, thanks. I owe you one.I've updated his picture with labels for each pipe so far - just waiting for the last 2.
Yes on the positions. Thank you!So.. the 2nd from the right controls the pool returns and the 3rd from the right controls the bubblers.
I’m not there now but water was seeping out of the led conduit (yet to be installed) I ended up gluing on a cap which stopped that leak. Will see this evening if the water level holds.I suspect it drained down because of the bad Intake valve position
Thanks for tracking the process and labeling the pipes/valves. Getting that sorted out has given me some reliefHere is a modified version of your picture with labels.
Two things, first is that the spa went down 1/2 inch within a few hours. I don't know why, if it needs a check valve or what. The unoccupied LED conduit is capped and glued so no water is escaping from there anymore. Last night I did slightly open the valve just to get some trickling over the spillway as not to let the plaster get exposed.Normally, when you have a spillover spa, you have something called a make-up line that feeds a little water to the spa when the system is in the pool mode. This water causes the spa to overflow into the pool.
You are right, without having the check valve sitting on the deck itself, there is no room under that valve to add anything.The only issue is the lack of real estate in that spa return pipe above the concrete deck.
It does make things unnecessarily confusing.The guy who plumbed your equipment pad did not do you any favors by using some 3-way valves where he should have used only 2-way valves.
Why did you say that I don't need to operate the bottom drains in the pool right now?
