results after 4 days of opening the pool, what should be tweaked
Andy,
Looks like you are pretty close to me.. :p
pH is a little low but I would expect it to increase pretty quickly on it own.
CYA really should be 70 to 80 so that is a little low, but not a major issue.
FC is ok, but at the lower limit... See this chart... https://www.troublefreepool.com/content/128-chlorine-cya-chart-slam-shock
I'd like to see your FC up at 4 to 5 ppm so that you are not so close to the lower limit where algae can form.
All and all not too bad.
Thanks for posting,
Jim R/
