Researching which SWCG to get for my above ground.
jlyfshhh
94
Georgia
Came across this, which seems great for the price and simple installation, but wanted to see what the experts here think:
Solaxx says it outputs .4 lbs in 24 hours
Poolmath says that is 3.7 ppm in 13k gallons. It might not keep up in the peak season in GA, but the price is right if you don't mind supplementing it with liquid chlorine as needed.
Do realize with 24/7 runtime needed and longer season, you'll reach its end of life quicker.
When comparing SWGs, you want to look at chlorine production (lbs. per day) vs. price. Although rated at 20,000 gallons, the unit only produces [only] 0.4 lbs of chlorine gas per day. That equates to 6.4 oz which will increase FC in your pool by 3.6 ppm. In peak summer months, your pool probably loses 3-4 ppm per day. You would need to run the SWG (along with your pump) ~24 hours to meet daily chlorine needs. That get expensive with a single-speed pump.
I don't know anything about that system. Shop around a bit for better values. Check out the various Circupool models. If you want to take a chance with off-brand systems, check out the Calimar units. @bowenpan recently purchased and installed a 40K gallon system that produces 1.45 lbs per day for $625. Here's the thread:
EDIT: @Newdude beat me to it...
