mentaimotse
12
Summerville, SC
I have a Pentair Clean & Clear with 5,000 gal AGP currently connected via the stock hoses and am planning to hard-plumb this weekend. I thought I'd submit my plan here in the event anyone can see issues/opportunities for improvement. All valves (with the exception of the drain valve) are Jandy-type, as is the check valve before the pump. It may not be clear in the sketch, but I was planning the check valve to be placed to keep water from backflowing back into the skimmer so I don't lose prime, especially when draining through the cartridge filter. The valve on the drain outlet will have a barbed fitting so I can attach a flat hose as needed to help drain rainwater during the wet season. This pool is chlorine.
Thanks in advance!
