Hi Everyone,
I got a bit rambunctious trying to unscrew the top of my chlorine feeder and ended up cracking the output pipe. Here's the crack.
I can't imagine there's any way to fix the crack. Originally, I was planning on replacing it, but I'm not sure how to go about that even. The feeder screws into fitting on either side, but I don't see any way to unscrew it without cutting a pipe somewhere.
I've decided now not to replace it. I hadn't been using it anyway and really just thought of it as something to use when on vacation or away. Now, I've decided I want to remove it and ultimately install a liquid chlorine feeder. I've been reading on this forum about setting those up. That will satisfy both the everyday usage and keep everything in good condition when I'm not around to add liquid chlorine.
I'm having trouble figuring out how to get the system repaired so that I can get my pump running again. But I want to do it such that I can easily add a automatic liquid feeder soon. Ideally, I'd also keep it where I can add an acid feed system too.
Here's my total setup.
On the left hand side, I can cut the pipe at the chlorine feeder and have plenty of pipe left attach a union to. On the right, though, the feeder goes directly to the elbow. It looks like I need to go all the way to the multi-port valve and rebuild the section with the check valve to. Anybody see another way?
It looks like the grey piece is screwed into the multi-port valve. So the original install must have screwed that in, and then started glueing everything together from there. Does that sound right?
What should I install to replace the feeder so that I can add a liquid feeder?
Thanks for your help and ideas.
