Well, mostly due to cowboycasey pointing out last year my use of DWV PVC fittings (yes, I know my return STILL has 2 pieces), I started piecing together a new plumbing setup using standard Hayward Intakes and return fittings and completely eliminating the Intex parts and finally had a chance to put it all together. I also redid the pad since I had it all apart. Once I am comfortable there are no leaks, I will move the rubberized mulch back over the pipes. The section you see going around the backside of the pool is for a fountain and has a T fitting with a drain plug making winterizing easier. Next project is adding a Circupool Edge15 as my Intex SWG is throwing errors (probably just needs new plates).
