Hello to everyone,
The black stains in the picture started coming 4 years after we moved in in 2001.
No one knew what they were and I made everything worse by putting 3" tablets on them, dry acid in a sock, etc.
Finally decided to get it re-plastered. 40,000 psi hydrojet to remove plaster.
When hitting stains with hydrojet some voids opened up around an abandoned in-ground cleaner system.
Bad patch job?, ground water?, don't really know.
Haven't found all pipes but some areas that had a stain I see some rebar where the hydrojet exposed it. Pool re-plaster guy believes the stains are from the rebar.
Wants to fill all areas with hydro-static cement.
Also what I thought were 2 main drains for 18 years, one has a hydrostatic plug and the other one looks like it's full of original plaster.
After looking up in-floor systems I thought a main drain was originally needed?
Hope some of this makes sense.
Please, looking for some opinions, ideas, anything on what to do.
Thanks
Thanks
