If you buy a complete intelliflo you dont need to change the impeller leave the impeller and diffuser on the motors they came on.
As an upper limit, it will really be dicatated by the maximum flow rate spec of your filter but 15 PSI is probably safe. On the low end, I wouldn't go below 800 RPM because the Intelliflo energy factor starts to drop again.H2Ocare said:How should I decide what's the maximum speed to program this baby? Should I ramp it up and look at the pressure in the filter?
I am not sure I understand that. Why is the pump so far from the valves?H2Ocare said:The distance from the valves to the pump is 20 feet.
mas985 said:I am not sure I understand that. Why is the pump so far from the valves?H2Ocare said:The distance from the valves to the pump is 20 feet.
