That solar cover you setup is awesome! Great idea. Now that may actually work for me. Everything else I looked at wouldn't fit the bill. Now knowing about your system and reconsidering our drought, that may work.
Post #36 shows my solar controller: Pentair Compool LX220 Solar Control System. I don't think it has that feature you are talking about.
Post #113 states how I learned about the difference between the Maxflo SP2302VSP and SP2302VSPND. If I went with the SP2302, it would be the SP2302VSP and as a result, even if I wanted to go with an automatic controller that could work with it such as the OnCommand, by not having the SP2302VSPND model, I lose the ability to not have to touch the pump at all. I would have to use the control module on the pump to change pump RPMs, etc., where as the OnCommand would be used/manipulated for the solar. Not worth it to me if it could save me a little $ from having the solar and pump communicate automatically with ea. other.
If I wanted to do it right, then upfront costs would now be the Maxflo SP2302VSPND as well as a controller like the OnCommand. I would have to look at what that would cost me.
Edit:
I called Hayward about the MaxFlo SP2302VSPND model (remember, ND simply means No Display). They confirmed that that would be the model to use with the Prologic, E Command 4, or OnCommand, and which would allow me to have full automation and control of the pump. Problem is, is that the SP2302VSPND is so new that is not even readily available to the masses yet. Apparently, he was saying that I would need to check with the pool shop to see if they could special order it. I asked for costs, and he did not even have that. My thinking is that the cost will be through the roof for this version of the SP2302 at a pool store. I can get the SP2302VSP right now for $650 at
http://www.poolcleaningparts.com/hayward-maxflo-vs-sp2302vsp-variable-speed-pump.html w/ no shipping/tax. Maybe the ND would be less b/c it doesn't have the control module.
Edit #2:
Called my local shop, Vally Pool Center. The guy there knows his product a heck of a lot better than any dang Leslie's person I have spoken to. Not to mention, this is where I go to get my 12.5% chlorine as Leslie's doesn't even carry that. Clearly I am biased against Leslie's. Back to discussion at hand. The guy said he will check with his Hayward rep. on Fri. about the ND model and pricing. I shall update you all when I get this info.
He was saying that he recalls leaning that the Ecostar could work to turn on solar by sensing low voltage. He was not sure if it was the Ecostar, but if that is the case, that would be cool. I think I read something about this, but if I recall right, it was on the V-Green motor or EcoTech or something.
