Hello,
I’m a new pool owner as of last year. The pool is about 6 years old and was professionally installed by a reputable pool company with a complete pentair system. I’m looking at ordering a Pentair VSF (011056) to replace existing pump (Whisperflo 011514). The power bill is very noticeable when I run the pump and it’s pretty loud, so I like the idea of longer water flow at lower rpm’s/power consumption. Would this be a good move? On the replacement, I plan on using unions on my 2 inch piping. I currently have a nipple? Just ahead of the suction side of my pump, I have a Jandy valve. Is it possible to get the pipe out of the valve without damaging it? I assume it’s glued in. Also, on the discharge side, there is a sensor that is tapped into the pipe with a wire that leads to the intellitouch panel. Is this a temperature sensor? Will I need that sensor if I integrate my new pump with the intellitouch? Thanks in advance for any help you can provide.
