I thought this might be of interest to some people -- I have a Pentair CCP420 filter on a concrete pad with the pumps, and opening the drain makes a big mess everywhere, so I wanted the ability to connect a hose to a better location when cleaning the filter or draining excess water from the pool. Other threads showed this for filters with horizontal drain ports, but the CCP series has the drain plug vertically in a recess under the filter, so putting fittings on is not as simple.
After browsing the local ACE PVC fitting aisle, I came up with:
- 1.5” -> 3/4" reducer
- 3/4" street elbow (male on one end, female on the other)
- 3/4" short nipple
- 3/4" ball valve
- Hose adapter (3/4" male pipe thread on one end, male hose thread on the other, plastic)
By reducing to 3/4" I was able to screw the reducer in, then the elbow into that with plenty of clearance before adding the rest. I used teflon tape on all of the male threads, and it doesn’t appear to be leaking at all.
Obviously this won’t drain as fast as a 1.5” pipe would, but it’s a clear 3/4" path and seems to work fine. It will vary with your pool size, pump speed and plumbing, but I can drain an inch of water in about 20 minutes, so I just set an alarm on my phone or watch to come back and close it up. It’s probably better to have a somewhat restricted flow to keep enough pressure in the filter that air doesn't enter the system.
Pictures:
- 3/4" short nipple
- 3/4" ball valve
Pictures:
