Friends,
I have a 30K gallon salt water pool with liner. The pool was built before we purchased the home. I suspect the pool is ~15-20 years old. I’ve already replaced the pump, and now I’d like to replace the DE filter.
The current filter is a Hayward DE-3600. I’ve already replaced the valve and the filter fins. The current problem is it doesn’t filter well and when I add DE to the skimmers, most all of the DE ends up back in the pool (on the floor). I suspect I have a cracked manifold or some other issue.
I’m attaching a picture of the current set up. Would you recommend a new filter? If so, which one? I’m thinking about the Hayward DEP 100. I have a budget of around $1,000. I mainly want low maintenance, effective filtering, and long-term value.
Thank you.
Thank you.
