Hi Folks.
In a posting several months ago, I noted that I had tear down my 24' AGP that was from Costco because the lower rails were rusting significantly. That being said, I'm looking to replace this and thinking about going with an all resin pool.
I have a couple of questions regarding this:
1. I had my old ground bonding loop around the old pool with lugs attached to 4 uprights. With an all resin pool, even though the uprights appear to be steel...doesn't the bonding get affected especially when many of the tracks are resin and non-conductive? In this case, it would seem that only the metal uprights would be bonded and seems like its not really as useful.
2. Is it worth going down the resin path?
3. My previous filter / pump was a cartridge setup. Seemed to work ok. Curious if sand is worth considering on the new pool? Or just go with what worked in the past with the filter cartridge setup.
The previous pool (although we only had it for about 4 years), was fine except the rails were not galvanized...and the paint was not baked or even powder coated. It flaked off and that is what started the cancer of rust. The walls were galvanized and painted...I had no issues with those. uprights were galvanized and painted...no issues there either. Top ledge was resin...it was ok...but could see some fading from the sun.
Really my main issue was the rails being so crappy. Maybe as I type this out...I'm talking myself out of a resin pool. I just would like to know if the next pool I buy is galvanized and painted correctly and not the lame short-cut type of rails like I had before. Was really disappointed that I had rusted rails in the first year of use.
Thanks.
-J
Thanks.
-J
