Not that I'm slow at doing things, but when everything here froze in 2021, my pool was damaged. Several fittings broke, several Jandy Neverlube valves cracked, the chlorinator broke, and basically the pool was spurting like a fountain when the power went out at 0 degrees outside at 2am, so by the time I noticed about 5am it was all over but the crying. I initially couldn't get anyone to come out, since everyone was swamped, so I bought parts and was going to fix it myself. But I figure out that if I returned all the water to the hottub, and let it spillover into the pool, and then used the pool returns and skimmers to return water, I could bypass the broken parts. So it sat. For 2 years. Now another cracked valve has started leaking, and I have to finally fix this. But I've had two different companies ghost me, so I may be back to fixing it myself. Hence my questions.
1. I have glued pvc a bit on different projects, always straight sections where I can glue, push together, twist, hold, and done. But several places, especially 2 of these Jandy valves, are 3 way. So no way to twist the pipe three ways. So is there any tip for how to make sure the glue is spread if you can't twist it?
2. Is it better to just glue the actual segments of pipe directly into the valve, or do something like glue short sections into the valve individually, then join these short sections to the equipment with couplings (so if those joints leak I could cut them out and try again and nut ruin the valve).
Any other tips? I'm going to replace 4 Jandy valves, a chlorinator, and a lot of pipe!
Steve
Steve
