- Jun 11, 2017
- 119
- Plaster
- Hayward Aqua Rite Pro (T-15)
My equipment is lower than my pool and all of my cheap valves have handles breaking and are sticking. i am convinced that the Jandy neverlube Valves are the way to go. The plumbing has so little room that I am concerned about making the change, that said, there is a part of this process that I really do not understand.
One of the valves I need to replace is the suction side of my of my polaris. One tech I spoke with talked about the need to use plugs in order to replace the valves. Since my equipment is below pool grade, once you saw into the line and use a plug to stop the flow, how do you work on the side of the cut where the plug is installed? It seems to me you would need to glue to that side of the pipe with the plug in place and I just cannot think through how you take the plug out prior to installing the new valve? It almost seems to me that you would need to install the new valve up line from the old valve so you can make your cuts with the old valve turned off and open the old valve and leave it?
I just cannot wrap my brain around this and sure do not want to drain my pool to replace valves. Thanks in advance for helping me with this
Jan
Jan
