We have an inground 30K gal pool with attached spa. Landscapers broke the elec conduit for the spa light and water started leaking out. Tested light and it still worked ok. Cut conduit with pipe cutter, pulled wiring out going to control box and installed a short piece of conduit.. Re-filled spa and water no longer leaks out. However when light is turned on, the GFI breaker trips immediately. Figured the wiring didn't survive being pulled back thru the conduit so I started looking for a replacement fixture.
We installed a LED bulb abt 3 years ago and want to re-use it but I'm having trouble finding a small spa-sized niche-type light fixture with the old fashioned screw-in bulb connection (Edison type?).
Looks like any standard house bulb would screw in to it.
All I've found so far are the halogen 120V (with oddball elec connection) and some 12V options.
Are these no longer made? If discontinued, where can I find a part# so I can search EBAY or something?
Thx!
Thx!
