Replacement of check valve flapper
tstex
2,186
Houston, TX
Hello to all,
Need to replace the ckeck valve flapper that separates the back flow from the puck dispenser to the heater. I only use pucks when needing to increase my CYA.
The first pic is the ck valve, the second pic is an overall pic w Ck valve just right of the heater and left of the filter.
My question is what do I need to drain so when opening up the valve, I'm not spilling water everywhere? I would assume opening the air relief valve on the filter, is there anything else recommended?
Thank you
tstex
Looks like closing the valves to isolate the check valve are after it and the one before the filter. You will spill water but only what's in the line.
I use Magic Lube on the o-rings, not too much. I don't know about lubing the check valve.
