Hi Folks,
My old Jandy Lite 2 has been terminally ill for a few years and finally bit the bullet last week. Looking to replace with another 400k NG heater, thinking either a Raypak 406A or Jandy JXi. Reading the forums it sounds like the Raypak is preferred, primarily because it is easier to self-maintain which is what I've been doing with the old Jandy.
I'm looking for recommendations on where to purchase and for installers - I'm on the North Shore of LI.
Also wondering:
1) Is there usually a price advantage to order online and just have installed vs. purchase through installer?
2) Can both heaters be set up to turn on/off and/or adjust set point via an app (using wifi/z-wave/whatever) and how hard/expensive is that to make happen?
3) I currently have an off-line chlorinator that I use in the early season and when on vacation, any reason to switch to an in-line one?
4) I also have a tap before the heater that goes to a booster pump but I don't use a polaris anymore. Is there any reason to eliminate the tap and plumb the booster return in after the new heater? Or will the increased flow to the heater not make a difference? I have 3 skimmers, 5 post-heater returns and the booster pump (pre-heater) return.
Jonah
Also wondering:
Jonah
