So I have a single speed Hayward Power-Flo Matrix M/N: SP5500Z2 and it sounds like it is strained while it is running, almost like a pebble is bouncing off the impeller. I have checked the impeller, and there is no debris there so I figure the bearing has started to go on it. If I am reading the serial number right the pump is from 2008. I have been kicking around replacing it with a dual or variable speed pump.
My question is, how do I determine which pumps would be sized properly for my pool/filter?
