Daughter's new home has 15 year old or so in-ground plaster heated pool that needs the filter and pump replaced. They also want to add in salt water system to replace chlorination need (not sure if a good idea or not; perhaps another thread for that?). They use a cleaning system that does not use the filter for power.
An estimate of the pool volume is 25,000 gallons.
The current system:
She was quoted the following by a local, well respected pool service company:
Pentair Intelliflo VSF Variable Speed Pump $2,795
Furnish and Install one (1) Pentair Intelliflo VSF Variable Speed Pump. Unit to be installed in the area of the existing pump.
Programming of unit and training to be reviewed with the customer. All Parts and labor included, as well as, removal of current unit and replacement of pool and spa drain valves.
Pentair FNS Plus 48 DE Filter with Multi-Port Valve $2,050
Furnish and Install one (1) Pentair FNS Plus 48 DE filter with New Multi-port Valve. Unit to be installed in the area of the
existing filter. Old filter to be removed. All parts and labor are included.
Saltwater Chlorination Conversion $2,795
Furnish and Install one (1) Pool Pilot Digital Water Purification System (for pools up to 35,000 gallons) with sacrificial anode.
Includes salt, power supply, cell generator, sacrificial anode and labor. Wood pole will be installed to mount the power center if needed. **Salt Generator: 2 year manufacturer’s warranty applies**
Add on: Installation of blower $425.00 (for a small section of pool near shallow end).
Total wo the blower: $7640.
Some basic questions that likely are hard to give short answers
1. Variable speed vs single speed? Some discussion of Department of Energy requiring variable speed only? Does variable speed work well with saltwater systems?
2. Pentair vs Hayward equipment? Is there any general preference for one vs the other?
3. Pricing seems way high to me. Local Leslie's offers installation for $150 for a limited time.
4. Chlorine vs saltwater system? They used bleach last year reasonably well but a friend suggested salt is easier. True? Relative costs?
5. Other comments appreciated!
Thank you!
The current system:
Thank you!
