- Aug 4, 2008
- 47
I currently have a Polaris QT blower from 2008 that pushes air for a bubbler feature in the pool. The motor works but the plastic brackets that hold it in place have broken which causes the motor to shift up and break the seal that allows it to push air into the pipe. The same thing happened several years ago, but I was able to get the parts I needed to fix it back then. The filter foam is also falling apart, and I can't find that part either. I could probably fix the bracket with epoxy, but I should just replace the blower.
I could replace it with the Jandy-Polaris which seems to be the same blower but is there a better brand I should be looking at to replace it. I'd like something as quiet as possible.
