Replace Intermatic timer with what?
earnie
Active member
May 27, 2009
25
I have 2 intermatic timer the T version. Yellow dial. One control hayward max-flow xl pump and other one control polaris pb4-60 booster pump.
Both the timers are not working. Thinking about replacing with wifi digital timer. Any suggestion/recommendation which wifi digital timer I should go for which can control both the pump and reasonable $$$.
Thanks
so the hayward max -flow is 1.5 hp and pb4-60 is 3/4 hp. Will below work for me?
Suraielec WiFi Pool Timer, 120/277V Individual Switches Pool Pump Timer, 40 AMP, 2HP, Indoor/Outdoor Wireless Smart Switch Light Timer for Pump, Water Heater, Spa, Heavy Duty Electrical Appliances?​
According to the manufacturer, the device can control two 120 volt devices, but only up to 1 hp each. This screenshot is from Amazon Questions & Answers:
If you look at the directions, when they say two 270v devices, they are only switching 1 hot leg on each which i understand stand to be less than ideal (and possible not NEC compliant)
