I've got a Sundance Cameo spa built 3/16/99. The third heater just failed on it within the past 3 years. All of which shorted out and tripped the breaker. With the heater disconnected the rest of the tub works just fine. The flo switch is about one year old and the hi-limit switch is about three years old. I have owned the tub for about 6 years. Every once in a while the digital control seems to have a mind of it's own and won't set and occasionally jacks the heat up to about 104. I read somewhere that with repeated heater failure it could be a chattering contact switch? I can't afford at $150 a pop to keep replacing heaters, obviously something else is wrong.
