- Nov 12, 2017
- 12,694
- Plaster
- Pentair Intellichlor IC-40
I'm the party pooper...
It's not uncommon to run a solar heater as a completely independent system. Given your electrical cost constraints, that might be a great way to go. Never having done that myself won't keep me from chiming in about it, though!!
Depending on the panels, you might have to look into some sort of rudimentary filtering. You need to pump clean water through most panels, many of which have very small collector tubes that won't tolerate particulates.
More importantly: there's a common misconception about the amount of flow needed by solar panels. Stop me if you know this already. The myth being the slower the water goes through the panels, the hotter it'll get, the better it'll heat your pool. To get maximum efficiency out of solar heaters, you actually pump a lot of water through them and only raise the heat of the water a degree or two. Super-heated water running slowly out of your solar return will do very little to heat your pool.
Similar to your plan, I run my pool off PV panels, so with those and the solar panels, my pool heating/filtering/sanitizing is "free" (not counting wear and tear, maintenance, etc). So I'm with ya there. But the eight solar panels required to do a decent job of heating my 12K pool need 40GPM of flow! That's a big Pentair VS running at 2200RPM. Granted, I have to also push that water through a filter, NG heater, SWG, etc, so I got a lot of resistance, which you'll be eliminating to some degree. But you're still going to have to push a lot of water. Something to consider when you select your motor and PV panel. I'm guessing they're not going to be as lightweight as you might be counting on...
I think where the panels are mounted are not so critical. If they're on the roof, then the water you'll be pumping up there is being pulled down by the water coming back. So you're really only needing to overcome the friction of the water through the pipes. But you do have to force a lot of water through the panels, so there's that. And since you have to drain solar panels at least once a day, you'll have to fill them once a day, so while you don't need much horsepower to keep the water moving, you do need a good amount to get the initial fill of the system. So that's something else to consider when selecting the pump.
I'm sure there's some math you can do. You'll need to identify the brand and number of solar panels, and figure out their collective flow rate requirement, then add in the pipes and filter, etc, to calculate the required pump size. (I think these are "head" calculations, but I don't even know the terms, let alone the math!). Hopefully someone else here can fill in the blanks...
