I have a small crack in my Gunite hot tub that I would like to repair. The crack causes about an inch of water loss a day in a 400 gallon hot tub. Someone has tried to repair it before, but I understand from the previous owner that the professional companies will not attempt a repair due to the proximity to the jet.
I have done a dye test and I am certain that this is the area where the water is leaking from.
It doesn’t have to look pretty (obviously), but I am looking for recommendations on products I can buy for a DIY repair. Should I try to remove some of the previously patched material?
Thank you for your advice and suggestions.
