Hey Guys -
Last year, I started with whatever junk the pool store gave me (including the person dumping a LOT of stabilizer into the pool the very first day). It took me a couple weeks to find this site, and although the water has been perfectly clear all last summer, and even over the winter (I just pulled the winter cover and it's still wonderfully clear), The numbers seem high and to avoid problems I think I will need to do a drain/refill process a couple times to get things back on track.
Here's the pool when I pulled the winter cover off (the pillows lasted all winter, just deflating as spring came around, so that's good) a week ago (replaced with the solar cover):
And here is my new pool robot sweeping up the sand and remaining leaves yesterday:
So it is looking good, but some of the numbers like CYA are still out of whack, so I am looking for opinions. When I closed the pool late last Oct, the numbers were as follows:
FC: 25.0
PH: 7.6
TA: 210
CH: 230
CYA: 115 (or 120 or so - it was so high it was hard to get a good reading)
Temp: 55ºF
So I tested the water 2 days ago, and the tests came out as this:
FC: 9.4
PH: 7.3
TA: 210
CH: 240
CYA: 100+ (somewhere between 100-110)
Temp: 57.9ºF
So I am thinking that with the CYA as high as it is, and this pool being a 54" Vinyl lined pool, that I should drain the water 2/3 of the way (down to about 18" of water or so) and refill, then re-test and apply bleach/soda ash/muriatic acid as needed to bring the numbers back in line.
I thought I would ask here if the opinion of more experienced people in the pool game concur, or if there is something else I should do?
Thank you for such a great resource!
Jim
FC: 25.0
PH: 7.6
TA: 210
CH: 230
Temp: 55ºF
FC: 9.4
PH: 7.3
TA: 210
CH: 240
Temp: 57.9ºF
Jim
