So I have been having issues with reoccurring green algae every few days. I purchased the TF-100 and tried doing the tests but ran into some problems which I will do my best to explain. first, though, I figured a little background information might be helpful. My pool is a kidney shape 35' long and 16' at the widest point with a 500 gal spa attached with a spillway into the pool. I believe the total pool volume to be approximately 15,000 gal. I have been using granular Chlorine which was recommended by a friend of mine that used to build pools before he retired. I will post a picture below of the active ingredients. I also used to use a chlorine floater in my spa with tablets with the same ingredients from the same manufacturer but since the pandemic have been unavailable and I switched to the ones carried at Costco which I am starting to believe may be part of the issue with my pools chemistry and the algae problem.
On to the testing results
When I attempted to run the Chlorine Drop Test the sample did not turn pink so there was no Chlorine and was confirmed when I ran the daily CL test which also came back as 0. I tried continuing on to the FC but had added 35 drops and the water was not getting any clearer (If possible it seemed to be getting cloudier), so I discontinued the FC and CC test as I am guessing that if there is no Chlorine you basically can't run the rest of the Chlorine Drop Test? Please correct me if I am wrong here. The CYA test was also concerning as I couldn't see the black dot after the tube was only filled to about 1/4 inch BELOW the 100 mark. To me, this doesn't make any sense as I added about 3 cups of Chlorine granules three days ago. If the CYA is this high shouldn't there be some chlorine showing when I test instead of the zero reading I got when testing today? below are the rest of the results (The Calcium is concerning to me as well.
FC - Not Completed
CC - Not Completed
CL 0.0
PH 7.4
TA - 110
CH - 650
CYA - 1/4 inch below the 100 mark
Phosphates - 250 PPB (Test done with Taylor K-1106)
I could really use some advice on what to do next. I first thought I would need to add conditioner since the chlorine I add seems to be evaporating so quickly but the test showed that mine is apparently really high but that doesn't line up with the zero chlorine reading as far as I understand. Thank you all for any advice you can give, and please let me know if there is any other information you need.
FC - Not Completed
CC - Not Completed
CL 0.0
PH 7.4
TA - 110
CH - 650
