Hi! We are experiencing a lot of rain in the area we live in. Is it okay to remove water from my pool using the waste setting on the filter? Will it damage anything?
It will not damage anything. You absolutely should not walk away. Only do this if you are present. If the water gets below the skimmer, you can damage the pump. A better strategy would be to use a sump pump, or if you have an AGP, a garden hose siphon.
