I recently purchased a home that has an older pool built 18 years ago. This is my first pool. The pool has a 120v pool light that functions just fine. However, my young son constantly mess around with it and yanking it out of the niche. I also feel uneasy having an older light underwater even though I never turn it on at the light switch. I plan to in the future change it to a 12V light.
For now, I would like to remove the pool light wire from the pool power box. I have opened up the pool power box and saw that the pool light wiring has a black and white wire that go to a GFCI outlet. There is a green wire that goes to to an area that all other pool equipment green wires connect to which I believe is the ground area. My question is, is it safe to disconnect all 3 wires from the pool light from the power box and put caps on them? I read that the pool water is usually bonded to the pool light. Would me removing all the wires affect the overall bonding of the pool and the other equipment?
