Hey all so I’m planning to remove my light fixture to inspect and clean behind the niche if needed.
I think my gfci breaker goes out to the pool deck that is for the pump and the light there isn’t a separate breaker for each so if I turned the breaker off pulled the light out and left it on the deck can I turn the power back on to run the filter while the light is sitting on the deck?
Also if theres debris in the niche can I just take my vacuum hose remove the head an suck up the debris with the end of the vacuum hose?
