Is there a trick to removing the jet assemblies like the one pictured below? I think there’s some construction debris or plaster in the pipe behind it and want to remove it to see if I can flush it out. I’ve tried unscrewing it and that doesn’t seem to be the answer.
(No, I don’t drain the spa regularly. Had some work done on the spillover today so had to use the drain/fill functions to cycle the water.)
