Remove fine silt in-ground pool
texasphil
1
texas
Looking for low cost way remove fine silt off bottom of in-ground pool since Hayward DE panel filter is not removing it? Can I rent equipment? Don’t mind loosing some water for this task. texasphil.
Hey Phil and Welome !!!
No amount of filtering/skimming will suck up heavier debris off the floor. Whether it's leaves, twigs, silt, pebbles, etc, It needs to be vacuumed at that point. Your choices are the old school manual vac on a pole, or an automatic robot.
