Remote control of pool cover
Georgetv
Active member
May 4, 2019
33
Los Angeles, CA
Hayward Turbo Cell (T-CELL-5)
using Coverstar toggle switch located inside pool cover box. i want to control from inside house where i can see the pool only 10 feet away. i see coverstar makes a wifi model, but still need access from pool for maintenance visits. ideas on remote cover switches?
Reactions: Dennisan
Doesn't Coverstar have a push button key pad available? I've seen them. You can give the pool tech the code and let them open/shut the cover.
Remember that for your pool water its best to open the cover every few days at least to allow the water to
breath. Gases can get trapped under the cover and they need to dissipate and get exposed to the sun a bit.
Maddie :flower:
Maddie :flower:
thanks Maddie! Good tip on leaving it open every few days. appreciate that. they do have a push keypad i am trying to devise a way i can open and close the cover from kitchen window which is right above the pool rather than going to pool, opening the cover box and pressing the key.... ideas???
Did you get a solution I have the same issue
Take a look at post #29 in this thread.
Coverstar does not have "remote control" of their covers and appears to only allow one controller per cover. So, for a Coverstar pool, if you already have a switch, or keypad, or other control setup, you would want to extend that to a different location if the current one doesn't work for you.
