- May 7, 2021
- 61
- Plaster
- CircuPool RJ-60
Finally getting around to remodeling an old pool, plaster is off, coping removed, skimmer is out, hopefully things will start to be put on rather then taken off. After all the demo work, I'm left with a crack in the concrete. So the question to everyone here is, what does one do with cracks, that are seemly old and not expanding. I was loosing water through the crack since I bought the place 2 years ago, who knows how long is was really leaking for. Anyway I digress, do I...
1. Grid out the crack and simply fill with plaster?
2. Staple it?
3. Something else?
Ground water is coming back in through the bottom of the crack, though I figured once it's replastered, just as the pool water is sealed off so would the ground water, unless it can force it's way behind the plaster and cause problems.
Pool Skimmer view, close up of the bottom where water comes back in and then top of skimmer, can see where the water leaked out of it on the left of the skimmer.
Pool light area crack... Looks to be more cosmetic.
2. Staple it?
3. Something else?
