After 2 years of battling with my pool water, I found TFP. It has been a wonderful learning experience. I had CYA level in the 80-90 range I completely replaced my pool water and started fresh with a good understanding of the relationship between chlorine and CYA. My water has never looked so good. The pool is crystal clear. No algae issues and opening was a breeze requiring only a 3 day slam. I do a chlorine drop test almost daily. I like to know that the FC is around 3 and the CC I like at .5. To keep these numbers, my pool requires about 2-3 cups of chlorine daily. I have not added any CYA to the water. My TFP test kit indicates less then 10 ppm of CYA in the water. I’m reluctant to add conditioner. I’m convinced CYA buildup was my major problems for so many years. Would a small amount of conditioner help with my daily chlorine loss. And suggestion on type of conditioner/CYA. Also I have a vinyl liner pool, is there any benefit to increasing my calcium numbers. I’ll post my TFP test results. Thoughts and guidance is appreciated
