Hi guys
i’m in the process of moving the junction box for my pool light. When I opened the box, I found a bonding wire from the light along with the light cable. both running through the gray pvc conduit From the light. another conduit with 3 wires coming from the transformer on the side of the house. I’m replacing the light and extending the cables to the new cable junction box location. My question is how to extend the bonding wire. Can this wire be spliced in the inside the conduit? Or should I run a new wire from the light housing. The wire appears to be attached to the light housing but I don’t see a way to remove it and replace it. Looking for options. I have the pool drained so I think this is a perfect time to do this. I will attach some pictures of the light housing and the connection to the Bonding wire.
