A few months ago we bought a new house and the pool had been very poorly cared for. I’ve gotten it pretty well stabilized and now thinking about best path to restore it.
First big issue is that the plaster is bubbling and popping off on the first step. I haphazardly tried some underwater plaster patch to no avail.
The second issue is calcium (I think?) build up around all the tile. It is worst where the water runs off from the spa and you can see it on the brick from the fountain spash as well.
Is it time to replaster? Or is there something I can do to delay? And if so, should I wait to try to clean up the brick?
Im also wondering if those popoffs might leak water, or does the shell of the pool prevent that to some extent? I do lose water but I am not sure if it is evaporation or not since the bucket test has been inconclusive. Appreciate any advice!
If it’s of any use my stats are:
FC: 8
CC: 0
PH: 7.3
TA: 100
CH: 370
CYA: 85
FC: 8
CC: 0
PH: 7.3
TA: 100
CH: 370
CYA: 85
