I'm replacing the liner, skimmer, pump, heater, chlorinator and probably some other stuff too!
There's a lot to unpack here so feel free to just pick and choose any or all...
1) It's a 14 x 28' vinyl pool 8' deep with a small shallow end. Estimate 55,000 Litres. We are removing the entire concrete pad that surrounds the pool so we will have access to the return pipes, skimmer etc.
For some reason several years ago the liner around the skimmer became stained with a rust colour that bled downward in streaks and also stained the plastic of the skimmer. Does anyone know why this happened and how I can prevent it happening again?
2) Pump: From what I have read here I only need a full rated .5 HP pump. Should I get a 2 speed? Traditionally I run the pump 24/7
3) Heater: I have a Raypak RP2100 from 2002 so I think It should be replaced Ideas on good replacements?
4) I want to convert to a SWG system. My pool is by a forest and we struggle with a lot of organics; Spruce pollen blooms, Poplar tree fluff, cat tails, etc. so wondering if I should go with a system that is 3x the size? What are some brands you Pros recommend?
I also want an automated system that controls the chlorine and pH automatically. Because my chlorine can bounce around I'd like the system to monitor itself.
5) It's an oval pool with plastic wedding cake steps built in and they need replacing. Any thoughts on the latest options?
Thanks for your help!!
