We are refilling our 15000 gallon pool after having some work done. During the work, we did get quite a lot of water back into the pool as we’ve had a ton of rain here in central Florida the past month or more. That led to quite a bit of algae and even a bunch of tadpoles growing in the pool. The pool has been emptied now, dirt vacuumed out, tadpoles are gone.
The interior also has a bit of scale build up that we are trying to remove through careful pressure washing and possible acid washing. My pool builder is doing the work for now.
Anyway, for the refill I want to make sure I set it up correctly. I tested my refill water:
FC - .5
CC - 4.0
pH- 8.5+ (very red)
TA - 160
CYA - 0
Temp - approx 60F (need to get a good thermometer on this still)
CSI - approx .62
Any thoughts or concerns with the refill? I assume I will need to start with a shock and get chlorine back up to correct levels. I’ve always had trouble maintaining pH levels as it seems to go up very quickly and I’m adding muriatic acid a few times per week.
Do I need to test for anything else at the pool store or do I have enough info from my existing tests? Is hard water a concern? Ive been told it’s a concern but not sure if the CH test is enough to know for sure.
Thanks for all the help and input!
Tom
FC - .5
CC - 4.0
pH- 8.5+ (very red)
TA - 160
CYA - 0
CSI - approx .62
Tom
