Refilling pool after new liner
brandy71499
1
Mobile, AL
So I'm currently refilling my pool after getting the liner changed. I decided to test my tap water to get a head start. I hear a lot that TA does not mater if your PH is good. Is that true because my TA is really high. What should I do. Also is there an order I should add my new chemicals? It a chlorine pool btw.
PH 7.8
TA 1900
CH 300
Agreed, TA seems impossibly high. I’ve had issues with high TA tests before, don’t forget to wipe the dropper tip with a damp cloth between drops. That was my issue, wiped between drops, back to normal reading.
