Pump is currently at lowest speed to still adequately produce chlorine through the SWCG, so that was not an option. Gene, you were right about the INLET being at the bottom of the tee. However the pool builder did not put the INLET at the pump inlet. He put the INLET portion on the skimmer thus preventing any skimmer adjustments by me. This is fixed now.
What I am seeing now is that since I made that adjustment, I am getting small bubbles of air in the pump while it is running. This is with 80% of the skimmer now turned off. It is not apparent that there are any leaks since there is no water leakage anywhere around the valve that I just adjusted and all screws are tight. Also when I turn the pump off, there is no loss of water level in the pump housing so I do not think there is any air leakage around the valve. Hmm... another mystery.
