Reducer help.
Hfx
Active member
Apr 29, 2020
34
Alabama
I feel this maybe one of those “ right in front of My face “ answers, but I’ve looked And I am still drawing a blank, I need to find a reducer from a 2 inch 90 degree to a threaded intex pipe ( I think they are 1.5 inch ) I hope Lowe’s or Homedepot have something i can go pick up, and I am just being blind or not finding on their sites, as I’d love to finally get Our pool running tomorrow. thank you for any help and sorry if this is something simple I am overlooking.
Richard320
22,676
San Dimas, CA (LA County)
Thank you, i am still VERY new to the pool building scene, and although that is not available locally, it gives me a idea to hunt for tonight.
thank you
If you're going out in person, look also where the fittings for sink drains are -- the traps and so on.
maybe this? i would not be using the nut.
If it fits
Hfx
Active member
Apr 29, 2020
34
Alabama
Thanks, I am trying to avoid the outside world as much as possible as my wife and i are looking after her Grandmother who is recovering from a cancer operation, its why i was hoping to find something i could pick up rather than get out amongst the general public. the ID of the 2inch pipe seems closer to 2.25 than 2
Reactions: markayash
Mdragger88
284
Hernando, Ms
Pvc fittings are cheap- i would order multiple sizes just to be sure u have what u need. Also to avoid the threading difference problems u could just order standard pool hoses & intex adapters if you’re willing to wait for shipping here’s how mine is set up34BEDC54-6273-495D-A517-09D8945E0BED.jpegB72EFA1E-F91B-443C-9D3C-051377AE5E1F.jpeg3FF5D026-9C6D-42A8-AEC6-8C8F519F3D66.jpegC27E7C33-2A57-4D69-B374-5FC93245F487.jpeg
Hfx
Active member
Apr 29, 2020
34
Alabama
Pvc fittings are cheap- i would order multiple sizes just to be sure u have what u need. Also to avoid the threading difference problems u could just order standard pool hoses & intex adapters if you’re willing to wait for shipping here’s how mine is set upView attachment 139515View attachment 139516View attachment 139517View attachment 139518
Thank you, i literally just finished ordering $19 of everything i thought would work, hopefully it works or at least tides me over until i can get something more suitable.
thank you everyone. i now have hope :)
Reactions: Mdragger88
Mdragger88
284
Hernando, Ms
Spears 1436 Series PVC Tube Fitting, Adapter, Schedule 40, Gray, 2" Barbed x NPT Male https://www.amazon.com/dp/B008HQ73FO/ref=cm_sw_r_cp_api_i_Z7kWEb0X51GAS
State Warehouse Replacement Hose Adapter w/Collar Replace for Intex Fit for Threaded Connection Pumps (Pair) https://www.amazon.com/dp/B07S3GSX24/ref=cm_sw_r_cp_api_i_D8kWEbD9GF5FE
JED Pool Tools 60-345-06 Deluxe Filter Connecting Hose for Swimming Pool, 1-1/2-Inch by 6-Feet https://www.amazon.com/dp/B000PYB5ZK/ref=cm_sw_r_cp_apip_JwvpxQFeXRC1k
Reactions: Hfx
Hfx
Active member
Apr 29, 2020
34
Alabama
Can u show a pic of the setup your trying to accomplish? That may be more helpful - what’s the 90 for?
Sorry if my terms or descriptions are wrong this is still a learning curve for me, the pump is a 1/2 hp solar powered
Pump. I simply want to put it in place of the intex pump. So need to get the pump connection to the intex return, and then send it on to the sand filter. After that it’s all intex hoses again to the salt water chlorinator and then back to the pool. Sorry for the rushed photo i am juggling work and pool.
Mdragger88
284
Hernando, Ms
Yeah I would probably do away with those 2 intex hoses & 90’s
It would go - pump->barbed fittingw/ flex hose -> intex adapter
They sell the barbed fittings in a variety of sizes - you want whatever size fits on the inside threads of your pump. You’ll also need hose clamps.
there are also multiple lengths of the hoses available
The intex adapters & standard hoses are really the only way i have found around the connection issues- because of the thread situation.
the barbed fittings & hoses are standard on above ground pools & are also easy to come by. Pool places also just sell tubing by the foot too if u don’t wanna go for the hoses.
on my old pool i had hooked pvc to intex & i never was able to stop all the leaks.
Hfx
Active member
Apr 29, 2020
34
Alabama
Thank you, i will not pretend to fully understand what you said but it gives me some pointers for google. Our pool is ready for salt now ( well was until storms rolled in ) so i am keen for the family to enjoy it asap. And i am trying to avoid public places due to us looking after my wifes sick Grandmother, so hopefully i can figure this out and order something today.
thank you again for your advice and taking the time to give it :)
Mdragger88
284
Hernando, Ms
notice in the picture that the barbed fitting is screwed into the inside threads of my pump not the outside then the hose is attached with a hose clamp. Underneath that you see the intex adapter attached to the intex salt water generator & the hose is also attached to it with a hose clamp.
