- May 29, 2018
- 440
- Plaster
- Pureline Crystal Pure 60,000
Now that I have closed my pool, and taken out my pump, filter, and heater I want to plan for redoing my equipment pad plumbing.
Replacing Hayward 2HP Super pump with
Hayward SP3202VSP Tristar VS 1.85HP pump or ??
Replacing Jandy Lite2 Heater with
Raypak 406,000 BTU or Hayward Universal 400,000 BTUHeater (Have not totally made mind up but leaning towards Raypak)
Keeping my Hayward Perfex DE filter (model ECF5A, 80 gpm, Pretty sure 40 sq. ft) works like a charm so far
Is upgrading to 2” plumbing worth my while. Cost will be minimal, and the plumbing to the pool is 1-1/2”
I have read pros and cons about doing so.
Filter is 1 ½ fittings so would need to use reducers.
Pump and heater are 2 inch
In the pic, valve that is closed are my 2 skimmers, valve that is opened is my main drain.
Concerning the main drain, it goes into a T, would it be better to use a Y and 45 into the Y
Would like to put in a bypass at heater, so no water running into it when not in use (don't use heater full time)
Can I re-plumb pretty much as original (pic) or a better way ?
Thanks
Thanks
