Didnt know which section to put this in, so it got stuck here.
Long story made short, Friday evening I had a multiport valve failure. Pool apparently got pumped out as the pump ran.
I have a new multiport on the way. Sand filter was replaced by previous owners and will be reused. The current big unknown is the pump. Im not sure if its toast or not, and wont know until the plumbing is back together.
While I have had two years of perfect water with BBB, I am looking at converting to salt while everything is apart. Im basically cutting the inlet/outlet pumps off to stubs and starting the plumbing from scratch because I a) had no other way to disassemble it and b) would like to avoid this in the future.
So, lend me the pros and cons of converting to a SWG.
